Hi Guys
Hope someone can shed some light.
I am using zoiper as a SIP client.
If I register with iptel.org then calling username works fine.
if I call sip:[email protected] it fails. "BEARER CAPABILITY NOT AUTH"
ditto for [email protected]
If I register on connection-telkom and try the above, same result.
If I call sip:[email protected] from voipbuster, "I get a user not found".
My understanding was that SIP to SIP calls are actually peer to peer and that the SIP proxy really only returned an IP address for the User you are trying to call.
So where is the issue.
ZOIPER
Service Provider
Nat Router
I am using Telkom ADSL with a 4 port Marconi Nat Router.
Regards
ZOIPER
Service Provider
Nat Router
Regards
