skyworth android box netflix help
chimera012
Cape
Hey guys,my sister just got her self the skyworth tv box
https://www.takealot.com/skyworth-binge-android-tv-box/PLID51979040
on the packaging it doesnt state netflix support but she installed it anyway.
some times it wont connect she says and also being in SA netflix doesnt provide all the movies and series,like a region block...
is there any good VPN you would recommend
to get access to all of netflixs catalog of move etc
she on the other side of the country so im not there to help her and check it out
TIA
Hey guys,my sister just got her some the skyworth tv box
TIA
Pm send
Doesn't work with Netflix that I can work out, any suggesions?
I've seen posts somewhere of persons claiming that they side-loaded Netflix successfully.
I've tried but failed.
Hi, how do i go about installing it using this link?
Enter the link in your browser on the box, it should download automatically. (I use puffin browser)
When you go onto the main page of the browser the apk should be under your downloads. You can install the apk from there.
After you download it how do you install on the android tv binge box?
