Hi
I'd like to invest in a smart wifi light switch (i.e. not zigbee bluetooth z wave etc).
My needs:
1. Fit SA light switches as a replacement
2. Wifi and Google compatible
3. Physical switch for visitors
4. No inserting stuff inside/modifying existing switches. Only replace in toto.
See below options
ideaing.com
My needs:
See below options
Best Smart Light Switches and Plugs You Need 2023
Transform your regular plugs with smart WiFi light switches and plugs. Discover our review for the best smart light switches and plugs.
. Maybe cheaper to replace light fittings and insert smart bulbs
