F
Fudzy
Guest
I'm not sure if the competitions are used to test the banner's rotation algorithm but if they're not can you please look into a better way of delivering them?
Like a page with just the the banners in the competitions, you could include text box on that page which gives you your unique code and it will also enable tracking of advert clicks by user (for auditing purposes).
I've got no problem with visiting the page and then copying and pasting a bit of text from the page but what real benefit does that have to the advertiser? If you had a banner and then a question relevant to what the banner was advertising that you had to answer it would be a much better means of telling if the advertising actually got the message across.
I like the competitions, I just think it can be worked on to make it better for both the sponsors and the entrants.
