Scoperzor
Been rummaging through this forum and haven't quite found the answers I'm looking for, and wanting to make sure I'm on point given that I know close to nothing about this stuff.
Wanting a solution for load shedding, doesn't matter if it doesn't last the full 4h30, a few hours is good. I need to power my desktop PC and router, that's about it.
My desktop is a fairly high-end gaming rig, with an 875w PSU, but I doubt it ever uses close to that. On eXtreme Power Supply Calculator (not sure how accurate this site is to measure power), my usage clocked in below 500w which seems accurate given that I'm running a single Nvidia GTX 970 but nothing else really too fancy in the machine.
Question 1: Would I need to get something higher than 875w or just cover the 500w plus room for a margin/efficiency loss? Is it worth going for a 600w inverter or better to be safe and go 1000w?
Was looking at the following: http://www.geewiz.co.za/long-run-up...emote-no/upgrade_to_steel_cabinet_w_wheels-no
Question 2: How long would that solution generally last me in a single use, assuming I'm only using the PC as described above?
Question 3: Any alternate recommendations?
Question 4: Any tips on operating that kit wrt recharging and usage etc?
Thank you!
Thank you!
