Hiya
I can access some sites perfectly on uncapped IS 4mbit lite
Trying to access same sites on per gb IS adsl no luck
example
http://forums.dlink.com
http://www.thinstation.org
even google.com/co.za takes forever to come up, but gmail is perfectly fine (maybe as its ssl)
CAPPED:
ping forums.dlink.com
PING forums.dlink.com (64.78.164.232): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
UNCAPPED:
C:\Windows\system32>ping forums.dlink.com
Pinging forums.dlink.com [64.78.164.232] with 32 bytes of data:
Reply from 64.78.164.232: bytes=32 time=439ms TTL=40
Reply from 64.78.164.232: bytes=32 time=437ms TTL=40
example
CAPPED:
UNCAPPED:
