Hey
So I have been having a problem with my internet for the past month. I am getting intermittent request time outs. This does not affect normal browsing but I cannot game online at all as every 5-10 seconds the line drops for a split second. I have tried everything to fix it. The problem has to be with Telkom. I have called a Telkom technician and they have come out only to tell me that there is no problem.
I have tested all the cables, different computers, different routers. A house that is a few houses down the road from mines ADSL has the exact same problem. No, it is not because of WiFi. Tried different DNS servers. Tried resetting the routers. Because there are 2 houses in the same area with the same problem, it can only be Telkom.
Phone Number: 021 903 XXXX
I have a 4MB line with Telkom and 10MB uncapped data with WebAfrica. The other house is 4MB line with Telkom and 4MB uncapped data with Mweb. This problem is never-ending, no matter the time of day. I have also tried using different ISP accounts. Both lines syncing at 4096.
You can see the problem on the ping test below.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ping -t mweb.co.za
Pinging mweb.co.za [196.2.63.110] with 32 bytes of data:
Reply from 196.2.63.110: bytes=32 time=11ms TTL=122
Reply from 196.2.63.110: bytes=32 time=10ms TTL=122
Reply from 196.2.63.110: bytes=32 time=9ms TTL=122
Request timed out.
Reply from 196.2.63.110: bytes=32 time=16ms TTL=122
Request timed out.
Reply from 196.2.63.110: bytes=32 time=63ms TTL=122
Reply from 196.2.63.110: bytes=32 time=24ms TTL=122
Reply from 196.2.63.110: bytes=32 time=159ms TTL=122
Request timed out.
Request timed out.
Reply from 196.2.63.110: bytes=32 time=14ms TTL=122
Request timed out.
Reply from 196.2.63.110: bytes=32 time=12ms TTL=122
Request timed out.
Request timed out.
Reply from 196.2.63.110: bytes=32 time=25ms TTL=122
Also, here's a traceroute - Doesn't look like the exchange is congested either.
C:\Windows\system32>tracert telkom.co.za
Tracing route to telkom.co.za [196.43.22.222]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 10.0.0.1
2 * 9 ms 9 ms 41-133-104-1.dsl.mweb.co.za [41.133.104.1]
3 12 ms 36 ms 9 ms 197.84.96.138
4 10 ms 10 ms 9 ms vl92.cpt-hscore-1.optinet.net [197.84.2.2]
5 113 ms 29 ms 13 ms 197.84.5.225
6 23 ms 11 ms 10 ms 101.te1-0-0.cpt-pr-1.optinet.net [197.84.7.5]
7 10 ms 10 ms 9 ms 197.84.4.21
8 13 ms 10 ms 10 ms 196.43.25.205
9 43 ms 33 ms 46 ms 196.43.39.162
10 49 ms 33 ms 32 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.4
3.23.6]
11 49 ms 34 ms 35 ms nbsc-ip-bssr-1-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.30]
12 36 ms 37 ms 35 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43
.22.222]
Trace complete.
Someone please help before this drives me insane. I just want to game without constant lag spikes. What more could I do to try and fix the problem if a Telkom technician has already come and tested to the conclusion that there isn't a problem?
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
3.23.6]
96.43.23.30]
.22.222]
Trace complete.
