Hi,
I need help please. The PC has a J&W Performance Motherboard with onboard sound, which I can't get to operate, so I bought a Meccer 7.1 Channel PCI Sound Card, which will start to work but freezes the PC after a short while or just play no sound at all. I can restart the PC and then it will play for a short while before stopping again, although the player still counts.
Once Envy showed under Device Manager with Legacy, but after a restart, Envy was gone.
I assume the onboard is Legacy according to Device manager, but how do I uninstall it to prevent it from intervening with Envy24 Family Audio Deck v5.20a. It is not under Add/Remove programs.
I did deactivated (so I hope) the onboard sound under “Advance Chipset Features”, “South Bridge Configuration”, “Audio Controller” as “All Disabled”.
PC Specs:
IntelCeleron 430 @ 1.80GHz
1.99 Gb of RAM
Windows XP
Bought this year at Comp Corp (Cheap one since it is for mother)
Thank you in advance.
PC Specs:
1.99 Gb of RAM
Windows XP
