frikkie6000
- Nov 9, 2010
I am importing the following query into php my admin
Following error
MySQL said:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '--connect - alanbbr
SET search_path = public, pg_catalog' at line 5
Can someone help pls thanks
Code:
-- PostgreSQL database dump
--connect - alanbbr
SET search_path = public, pg_catalog;
--DROP SEQUENCE public.events_eid_seq;
--DROP SEQUENCE public.fuel_fid_seq;
--DROP SEQUENCE public.maintenance_mid_seq;
--DROP SEQUENCE public.vehicles_mid_seq;
--DROP TABLE public.events;
--DROP TABLE public.fuel;
--DROP TABLE public.maintenance;
--DROP TABLE public.vehicles;
CREATE TABLE vehicles (
vid serial PRIMARY KEY,
name character varying(20) NOT NULL,
make character varying(40),
model character varying(40),
"year" integer,
vin character varying(20)
REVOKE ALL ON TABLE vehicles FROM PUBLIC;
GRANT INSERT,SELECT,UPDATE,DELETE ON TABLE vehicles TO GROUP autotrak;
REVOKE ALL ON TABLE vehicles_vid_seq FROM PUBLIC;
GRANT ALL ON TABLE vehicles_vid_seq TO GROUP autotrak;
CREATE TABLE events (
eid serial PRIMARY KEY,
event character varying(64)
REVOKE ALL ON TABLE events FROM PUBLIC;
GRANT INSERT,SELECT,UPDATE,DELETE ON TABLE events TO GROUP autotrak;
REVOKE ALL ON TABLE events_eid_seq FROM PUBLIC;
GRANT ALL ON TABLE events_eid_seq TO GROUP autotrak;
CREATE TABLE fuel (
fid serial PRIMARY KEY,
vid integer NOT NULL references vehicles,
date date NOT NULL,
previous numeric(10,1),
current numeric(10,1),
price numeric(10,3),
volume numeric(10,3)
REVOKE ALL ON TABLE fuel FROM PUBLIC;
GRANT INSERT,SELECT,UPDATE,DELETE ON TABLE fuel TO GROUP autotrak;
REVOKE ALL ON TABLE fuel_fid_seq FROM PUBLIC;
GRANT ALL ON TABLE fuel_fid_seq TO GROUP autotrak;
CREATE TABLE maintenance (
mid serial PRIMARY KEY,
eid integer NOT NULL references events,
date date,
odometer integer,
notes character varying(800)
REVOKE ALL ON TABLE maintenance FROM PUBLIC;
GRANT INSERT,SELECT,UPDATE,DELETE ON TABLE maintenance TO GROUP autotrak;
REVOKE ALL ON TABLE maintenance_mid_seq FROM PUBLIC;
GRANT ALL ON TABLE maintenance_mid_seq TO GROUP autotrak;
INSERT INTO events (eid, event) VALUES (1, 'Change Oil');
INSERT INTO events (eid, event) VALUES (2, 'Rotate Tires');
INSERT INTO events (eid, event) VALUES (3, 'Change air filter');
INSERT INTO events (eid, event) VALUES (4, 'Change timing belt');
INSERT INTO vehicles (vid, name, make, model, "year", vin) VALUES (1, 'Legacy', 'Subaru', 'Legacy', 1991, '');
SELECT pg_catalog.setval ('events_eid_seq', 4, true);
SELECT pg_catalog.setval ('vehicles_vid_seq', 1, true);
Following error
