949BFN
I received this modem as part of the RAIN (Mweb) LTA-A package.
After doing an initial basic setup, I connected my laptop to the router's AP and (obviously) did a speed test. The D/L speed was pretty disappointing (sometimes less than 10Mbps). I went back into the interface page and started setting up the other router settings like port forwarding etc. Within 15 to 20 minutes after first turn on, the modem lost connection with the tower.
Initially, I thought I messed up some of the settings and first reset the modem to factory defaults via the interface. The modem was however still losing signal, so I did a hard reset by holding the reset button. That did not help either. The modem boots fine, showing full signal on the router with a light blue Mode LED. As soon as I connect a device to the modem, the modem loses signal (all signal LED's go out and the Mode light turns to Red.)
I took the modem with me to work to report the issue to MWEB. They without hesitation indicated that they would replace the modem (but that will take up to 5 business days). When I had a few minutes during the day, I plugged the modem in and to my surprise, it didn't crash (loose connection), when I connected my laptop. I left it on all day with my laptop connected, doing some more configuring as the day went on without any issues With just 3/4 bars displayed at my work address by the signal meter in the interface, I still managed download speeds of more than 60Mbps.
Got home, plugged the router in with the idea of connecting it to my ethernet network. First I had to turn off the router's DHCP server, and as soon as I had done that, the router lost connection to the LTE network. Same as last night. At first, I thought disabling the DHCP server was the issue, but even after a hard reset of the router, it is still displaying the same issue - as soon as a device connects to the AP, the router loses connection to the LTE network. No matter what I try, the router will not stay connected to the LTE network when I device is connected.
I know I have perfect signal at home, because if I put the sim in a B315s modem, I get download speeds of at least 60Mbps, sometimes touching 70Mbps.
I again spoke to support - the guy suggested that we replace the modem to see if that makes a difference. If not, they'll have to look at the tower.
Has anyone else perhaps experienced similar problems?
