Stuck between best PC build for 10k
K4atos92
Hi. As the title states I am trying to decide between two of the best options for a build (R10000) which I plan on getting in two weeks. The first bulid comes with more hdd space which I think will be useful for all the movies, games etc. i am going to get
Core i5-2500k R2137
Intel Media Series Z68DB R1122
2x 4GB DDR 3 RAM R452
2TB HDD R1138
320GB Ext. HDD R592
ASUS Radeon 7850 R 2848
Coolermaster Storm Enforcer R796
600W Huntkey - R625
DVD Writer - R145
The second build has a better gfx card (GTX 670) which I know is waaaay better than the 7850, less RAM, an inexpensive mobo, a slower CPU to the 2500K and less HDD space:
Core i5 3450 R1857
Intel Media Series H67BL R880
1x 4GB DDR 3 RAM R226
1TB HDD R881
ASUS Geforce GTX 670 R 4786
600W Huntkey - R625
DVD Writer - R145
So which build do you guys think I should go for. Your help will be greatly appreciated. Thanx:)
P.S. This all comes from PC Int, so if you guys have info on other retail stores which are cheaper, that can also help
thanks for the speedy response guys. So I guess its not always about gfx power then:)... Hardware Secrets gave that Huntkey psu a Silver award and they had a lot of praise for it which is why I am going for it :)
are you going to game on 1920x1080? then 7850 is fine , got me one the other day and bf3 ultra 2xmsaa and it plays fine :)
take the top build can get a ssd with it, maybe get the same mb and cpu from build 2 , to save some cash, but every rig needs a ssd!
unfortunately no... going to be playing at 1600 x 900 so I know the card is overkill for this res hahaha! yep, thanx for the advice on the ssd but I was looking at getting that the end of the year bcos I know the prices are steadily decreasing :D
Didnt think there was that much of a difference. And the i5 2500k offers almost similar performance to the i5 3570k according to Toms Hardware...
ivy bridge and a z77 motherboard. ivy bridge uses less power (77w) compared to sandy bridge's 95w. that makes for a more stable system. go for an HD7770 and you should be fine. unless you'll play 24/7.
Look at Antec PSU's instead of Huntkey imho.
edt: also you haven't listed an aftermarket cooler, it might be worth it then to go with sandybridge over ivy, then so it can keep a bit cooler.
I got a 2600k and 3570k both fast chips but the ivy bridge is running on the stock cooler and it gets extremely hot.
Why get a "k" processor at all if you are going discreet graphics anyways? Save some money that way, unless you also want to us the on-board graphics.
Do you think I will really need an aftermarket cooler? I only game up to 4 hrs in one session and I barely game anymore since I got school to worry about. Yeah I will take a look at them also thanx:)
I heard that the "K" processor is excellent at overclocking which is why I am opting for the 2500k:)
Okay that seems like a good idea then. Will make the change to IB then. Also I plan on not upgrading the PC for a while which is why I am going for a more mid-range card (7850) which should see me through for like 2 years...
Core i5-2500k R2137
2TB HDD R1138
320GB Ext. HDD R592
600W Huntkey - R625
DVD Writer - R145
Core i5 3450 R1857
1TB HDD R881
600W Huntkey - R625
DVD Writer - R145
The top one, too many cons for the bottom one. Check Rebel Tech for cheaper prices.
Rather get this motherboard instead of the Intel: http://www.rebeltech.co.za/index.php?main_page=product_info&cPath=19&products_id=6039
Suggestion for a better PSU: http://www.rebeltech.co.za/index.php?main_page=product_info&cPath=30&products_id=1763
+1 NomNom is spot on, only recommendation is that you might want to hold out for the rumoured GTX 660(Ti) to release possibly later this month, should offer performance better than the 7850 for around the same or slightly less amount of money.
Wow think I might just hold off the purchase of the gfx until the GTX 660 does indeed drop. From what I read it should slaughter both the 7850 and 7870 which I highly rate. +1 for the tip buddy:)
Someone posted a link to another brand with good pricing the other day that is also rebranded Seasonic. I can't remember the name or find the link though.
EDIT: I just remembered (or I think I did) that it's XFX. Still can't remember who sells them locally.
hahaha... Yeah to save you the trouble, I googled it and I think it could have been ComX :)
