Been struggling again since last month with intermittent connectivity, slow speeds and constant CRC and header errors (Robin Hills, 4 Mbps, MWeb uncapped). Of course all the initial tests (conducted by someone sitting on their backside in an office) all show "defect free", quite a contradiction considering as it's Telkom it probably started out with a defect... but I digress, Clearly there's still a problem considering I battle to get 1 Mbps sometimes and still getting thousands of errors in an hour (totally random). This is unfortunately also not the first time I've had these issues either, the last time (after months of logging calls)Telkom actually replaced my local lead, which solved the problem at the time (for a while...)
I've done all the obvious tests, changed routers, filters etc. etc. etc. It seems this is still either local lead / DSLAM / Exchange related.
The only odd thing (aside from the obvious CRC errors) I've noticed is the output power varying quite a bit; between 2,5 to 8 dBm. Any other ideas (other than chewing off my wrists)??
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0xB5
Capacity Used: 36% 49%
Noise Margin: 13.0 dB 13.0 dB
Output Power: 8.0 dBm 0.5 dBm
Attenuation: 14.0 dB 5.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x67
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 7660 (1 spurious)
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
Operation FW: embedded
FW Version: 2.5.42
Interleave Fast Interleave Fast
Speed (kbps): 0 4096 0 512
Cells: 0 1745509 0 9076859
Reed-Solomon EC: 0 0 16 9
CRC Errors: 0 1987 9 15
Header Errors: 0 765 19 30
Total BER: 0E-0 3836E-9
Leakage Avarage BER: 0E-0 4168E-9
ATM0
Watchdog Resets: 0
Subfunction: 0x00
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
FW Version: 2.5.42
