Telkom Boo Boo?
Hummercellc
Richmond, KZN
Just noticed internet was very fast so I logged into my router and got this.
I have a 4meg now 10meg line, and Mweb 4meg unshaped account.
ADSL Line Status SHOWTIME.L0
ADSL Mode G992.5 ADSL2+M
Upstream: 2048 kbps
Downstream:10240 kbps
Attenuation Downstream(db) 4
Attenuation Upstream(db) 4
SNR Margin Downstream(db) 29.2
SNR Margin Upstream(db) 18.7
CRC Errors 0
Upstream BER 612e-7
Downstream BER 0e-7
Up Output Power: 3
Down Output Power: -6
Here are two speed tests I have just done
I have a 4meg uncapped account so throttled will try and test with a different account to see if I get 10meg down
http://www.speedtest.net/result/2382683896.png
http://www.speedtest.net/result/2382701453.png
Are Telkom trialing ADSL2+ annex M? because my upload is high, or is this a mistake and will be short lived? (hope not)
I read your upload speed is high and then I saw the test. WTF even my CellC phone can do better. And you call that fast?
Upstream: 2048 kbps
CRC Errors 0
Upstream BER 612e-7
Downstream BER 0e-7
Up Output Power: 3
Which area do you stay in.
Lucky wish they would finally upgrade me, even my work down the road on the same exchange gets 6 meg :p yet I am stuck on 4 megs with 10 times better line stats.
You are syncing at 10mb, thats often normal for a 4mb account. Theyre 4-10mb account. Or am I missing something else? Or is it that 2mb upload? Cause thats pretty high. Not sure if that is normal.
