8ta Network Optimist
- Dec 24, 2011
B618 LTE connection - with 2 x Deco E4 Mesh - whatsapp calls not always incoming and on the PC which is connected via ethernet the skype and teams sometimes does the same, but when I send a text message through it is like it wakes up the router and then it rings. 2 x A32 samsung phones can do it from time to time when receiving whatsapp calls. Has anyone else came across this? The b618 wifi is turned off and I actually got the Decos to ensure it is not poor connection.
Is it perhaps the b618 Firewall ? Is there a setting to keep connection life ?
If I view the security cameras remotely it connects fine most times , however at times you need to reconnect a couple of times to get the feed., so it is not like it drops the LTE connection as it has an external antenna but it is like going into sleep mode. Thanks
