Telkom LTE
The_Librarian
Another MyBB
Super Moderator
Dark room in Adventure. Grues abound.
Hi All
Which router is the best for Telkom LTE connectivity?
And will it be able to run off from 12V? (We have a solar panel + battery installation at home, want to hook it up to that).
The 500Gb night surfer deal still is the best bang for the buck so far.
Regards
Ook
When I had the Telkom LTE Uncapped Package, it came with the Huawei B315...
Not great Wi-Fi but otherwise wasen't bad.
You may want to consider finding a second hand one and pairing it with a XPOL006 antenna.
Get a huawei mifi E5776... supports the 2300Mhz lte band and is superfast.. been killing 100GB+ per night on that night surfer deal
it has its own battery. good for 8 hours and hook it up to power bank.. and you sorted
Last week Friday I bought ZTE router (I forgot the model number) I bought it R999 at edgars connect. It can connect up to 10 devices it's not bad I can downlond 2.2 gig movie within 5 minutes. I stay in a township so network is not that good, I'm sure in a city with good coverage it will be much more fast.
One more. For night surfing any LTE modem will do a job. B315s is powered 12V DC. Telkom sells B315s with lithium battery pack. So yes, it can be powered from lead-acid 12V battery as well.
MiFi devices are powered 5V and can be permanently attached to the USB charger, use whatever is convenient.
