Telkom router 105wr problems
nephelyn
I got one of these routers from telkom on their do2 package. Had no problems with it for a year now, but lately i have had to restart the dam thing every time i come home before my laptop will connect via wireless. My desktop (connected via wire) is fine. It just seems that on the wireless side of things it freezes...
About two months ago i put it in bridge mode so to connect to other ISPs.
Anyone had a problem like the before? Anything i should try?
Yea, had the same problem a while back with the same router. Sometimes it would connect and others not. Problem did just go away though. I would advise if you are on contract with telkom tell them its broken and hopefully they will give you a different model. The mega 105wr was really not one of the better ones and has givin me many problems.
Also dont think the bridge mode will affect it at all. What OS are you running? Cause it would be much quicker just to creat 2 dial up connections for the two isp's
