Hiya
I've been using a Cell C sim in a ZTE MF668 dongle and TPLink MR3420 router with no issues. Decided to get an 8ta sim to test if I have signal and what the connection speed would be.
Simply replacing the Cell C sim with the new 8ta sim never connects on the MR3420. I've changed the APN to manual (*99# and internet) with no luck, even fiddled around with a couple other settings and still no luck.
Using the Cell C Connector app work fine, I can connect (albeit on the MTN network?) and everything works.
Is there something I'm missing? I've spent the last 3 hours searching the forum for a solution but found niks
Thanks!
Thanks!
