Ubiquiti Unifi Help Thread
Rickster
EVGA Fanatic
Joe'berg
A lot of threads all over the place relating to Unifi on myBB, so here is hopefully a mega thread we can use for all issues.
I'll start, ok I got a Unifi AP connected to a normal router, everything is fine but my brother says that his xbox keeps switching between moderate and open NAT.
On the router UPNP is enabled but I see on the AP there is also a UPNP setting which is off. Shouldn't the router do all that jazz and the AP relays all the info for the router or must it be enabled on the AP too?
Thanks.
Theres an official ubiquiti thread pinned to the top, or are you looking for unifi specific thread and not the entire ubiquiti brand.
As for the topic, enable it on the AP as well. From my experience I treat these as if they are the router themselves.
