Ubiquity PicoSation 2 WDS problem
antowan
Unknown
DLINK ADSL ROUTER provides Internet connectivity.
4 PicoSation 2s connected in AP WDS config with one directly linked to ADSL router via ethernet cable.
They all have the same SSID and are all on the same channel.
Problem is that for some reason web connectivity drops sporadically just showing local only access in windows...
Any ideas?
Can I just ask how did you get WDS to work to your PS2 ?
I have the following: AP3 MEGA 100WR (WDS root) --> AP1 PS2 AP WDS ------- AP2 PS2 AP WDS ---LAN
Now AP3 and AP1 work just fine as WDS, but AP2 cant see AP1 no matter what i configure it as, it simply does not pickup AP1. AP1 on the other hand picks up AP2 on -40db which is great..
Any ideas?
