Unifi Appiance issue
irBosOtter
I use a Unifi appliance for my home, been running it for over a year but now there is a issue, before I rebuild it anyone know how to fix this:
Suppose to show IP and interface name, I can ping it, so it still has an ip of 192.168.5.10
When I select 2 it just shows this:
Here's the details about the appliance if anyone is interested.
Looks like this software or underlying dependencies may have updated recently, resulting in Python issues..
Yeah I unfortunatly don't know crap about Ubunu, will be easier to rebuild then haha
It's not Ubuntu specific.. It's a missing module called yaml for Python..
You could try the following commands, if you have terminal access:
sudo pip install pyyaml
You may or may not get an error about pip not being installed..
Cool, moaned something about no python.... started installing it and at this point I think I screwed it completely haha
Thanks for the help though, think I will setup a vm backup for the appliance the going forward after the rebuild, do have a backup file so easy to re-deploy the appliance
is there enough free disk space on the appliance? that may be causing the issue.
Not seeing anything particularly OTT value add the 'appliance' is adding
You could get this up and running in a docker on a VM or even WSL if you use windows10
The publicly maintained Unifi docker's kept pretty up to date and runs very lean on resources
