Unstable connection EU mainly
Satedah
Hi, I see a couple posts floating around about potential issues, across multiple games.
I'd like to quickly get confirmation on this, is there a known issue at the moment?
As it stands, packet loss to EU servers across multiple different games, doesn't really matter which one I try.
Currently on a 1gb connection through vumatel aerial.
Yesterday at around lunch time I think, my connection suddenly dropped and after that things have been all over the place.
Local speed test is showing full internet connectivity. I've rebooted router and cpe device as well.
Let me know if you're aware of an existing issue somewhere, that pertains to packet loss, higher latency or otherwise, general instability for EU servers.
Your fibre line or fibre network is the issue, majority of games these days actually peer locally and if the **** was hitting the fan it would be affecting everyone. In my personal capacity i have no issues playing on international servers.
Do MTRs and troubleshoot with your ISP shouldn't be difficult to see the packet loss
Thanks for the input, it did appear to be a larger known issue, based off of browsing this forum. I think it depends how they're routing traffic. I think it was mostly JHB as well. Will perform some further ping tests should it reoccur tonight :)
