Hello boss I am using b315 router from telkom but now I want to use my network cable I have try to set my pppoe acount but nothing it seems work can you please guide meSounds strange... I would do the same as what sajunky recommend. 1) check the LED light on the fibre box to confirm your fibre is live. Get you Fibre provider to confirm as well (call them). Having ISP login details won't make the B315 work if the infrastructure/fibre to reach your ISP is not live. 2) once confirmed that the fibre is live indeed, check the LED light on the fibre box and confirm which LAN PORT on the fibre box is active. Normally LAN/WAN 1. 3) connect a LAN Cable from the fibre box to the WAN port of the B315 4) capture your ISP details again and resubmit/save (must be a PPPoE connection) 5) not sure if you have another router on your network handing out IP addresses to your network - if not, then let your B315 be that (DHCP on)
I had reset the router before I started the above process - just in case - to flush out any potential clashes. That's all I changed (have no sim card in) and it's still working 100%.
Hello boss I am using b315 router from telkom but now I want to use my network cable I have try to set my pppoe acount but nothing it seems work can you please guide meAh great thank you guys! It's workingPretty embarrassing but it appears that the other LAN ports were disconnected.
