vga adapter advice for graphics card
zubs10
Hi Guys
I have just purchased the Nvidea Gtx 650 Ti Boost Overclocked edition (GV-N65TBOC-2GD ) and just realised that it does not come with a vga port connection. My pc screen only allows for a vga connection and i do not want to purchase a new screen.
Will a vga to dvi adapter such as this one work on the graphics card?
Hi,
Looking at the DVI ports on the card, it seems the bottom DVI connector supports both Analog and Digital signals. So yes, it should work.
Thanks. I was worried there for a moment but i will now purchase the adapter
