vicv
I drive a 2007 VW Polo 1.9TDI.
Currently while driving, when I start to put my foot down (accelerator pedal halfway) the engine will rev as if it is in neutral. If I slack off slightly the revs drop back to normal and the car goes in gear again. Note: This is a manual gearbox, it shouldn't happen.
It has previously happened only on occasion, but at the moment it happens too much and it happens mostly when the engine has been run warm (90C). Also happens mostly when I shift into 3rd gear, but it happens in all gears. Quite a big problem since I sometimes need to accelerate to avoid something and then suddenly I'm going nowhere.
What could cause this? Car now has 188000km on the clock.
Any help/advice would be appreciated.
