Websites not loading on first attempt
ItsJustJack
I changed from an Openweb 10GB account to SAOL prepaid account until the end of the month because the bundle was finished. Now, every time I load a website, the webpage immeaditely says the page cannot be found and then if I refresh the page it loads correctly.
How do I fix this? It is very irritating. I have run a ipconfig /flushdns and then ipconfig /registerdns which hasn't helped. Connecting directly to the internet and not through any proxies etc and running on Vista (happening on XP as well).
Any suggestions?
Hi
Try using the SAOL DNS as follows
Primary: 196.41.126.5
Seconday: 196.41.126.4
This should fix the problem, if not let me know and ill see what else i can find.
Allan
SAOL.com
Download the following app AnalogueX fastcache, then set your lan to use 127.0.0.1 as DNS, in the configuration for AnalogueX change the DNS to the abovementioned..
You will see a ASTRONOMICAL increase in loading (cached DNS name pages obviously)
