Wifi extender using an Ethernet cable
Monkeyz
Plastic Beach
Hey guys
i'm just wondering if there such a product
i currently have a TP wireless wifi extender but it cuts off at random because it looses signal from my modem
now i was wondering since i have one unused Ethernet cable could i plug that into something to give out the wifi signal
It’s always recommended to use a hard wired Ethernet connection instead of a wireless bridge.
Simply run the cable between the repeater and your router and change it into Access Point mode.
Make sure DHCP is turned off.
i see but my Tp link repeater doesn't support it
guess its times for an upgrade im guessing the asus RP-12 wireless N300 does support it?
Does it not have an Ethernet port at all?
What model is the Tp-link? If there’s an Ethernet port it will support it.
Any access point can be used in his fashion.
yea there is one port i used to use to connect my playstation too but in the set up site linkrepeater.net they don't give me the option to change modes
https://static.tp-link.com/res/down/doc/TL-WA850RE_V1_UG.pdf
1.2 on page 2 says supports one operating mode : range extender
from what i can tell there is supposed to be a option for mode next to the log out option
ok so i figured it out, the base firmware doesn't have the mode option so i went into TP links suppport site and updated the firmware and boom it appeared so now its connected!!!
Thanks for the help @Hamish McPanji @SauRoNZA you two are life savers
