Icemanbrfc
As the title says guys, which is the better of the 2 and why? I've always just gone for the Ethernet option, but I'm intrigued to know why WiFi option would be better.
Just in terms of general connections. Would I assume that the Ethernet option would be a more stable one?In what context?
Things do seem to be connecting alot quicker via WiFi over Ethernet for me at least
Websites and YouTube.Connecting to the network or to websites?
Ethernet.
If you connect your NAS via 300Mb/s Wi-Fi you half you connection speed on these:
1. Using Wi-Fi to router and from router to NAS etc. - data is send twice
2. Not Using 40MHz bandwidth.
3. Not having two antennas on all the devices - 300Mb/s requires two "streams"
Thus, the 300Mb/s can be reduced to 72.5Mb/s if everything isn't just right for Wi-Fi.
Hi
Would there be a performance difference between Ethernet and Ethernet over power line devices such as
http://www.tp-link.com/en/products/details/cat-18_TL-PA6010KIT.html
Never thought of it that way actually...I don't know about the speed but connecting your very expensive equipment directly to the power grid seems very risky to me.
Hi
