Wireless Antenna
craigdoepie
Kuils River
Scenario: I got a network setup at home and working perfectly, but now what I want to do is extend a wireless signal about 150 - 200m away. Its a friends place that is down the road. His has a flat above a garage, so the atenna will be in line of sight and the attena will be place on my garage.
Question: Can someone please advise me on which antenna to go for, I would like a stable and reliabe, but reasonable priced attena that can do the job above. Don't want to have issues when it rains or wind starts blowing. I have no idea what I am looking when they 5ghz or 2.4ghz and the dbi. I can make some conclusions, but my conclusions usually far fetched.
I am posting this in here as I think the guys that post in this forum are more clued up.
Thanx
Hi
Wireless is not an easy always work first time tek. you will need to create some kind of bridge setup between you and your friend.
What is your budget on this?
Don't actually have a budget, just checking around for prices and then will calculate if its worth it or not.
And here I thought it would be easy, just plug and connect. But guess nothing in life is easy
Hi
OK, do you also want to connect via the wireless, or is that just to beam to your friend?
If so I would sugest, an outside 2.4GHz 14dBi Panel Antenna connected to your switch, and maybe an Ubiquiti NanoStation Loco M2 on his side.
W
2 x ZYXEL WAP3205
2 x ZYXEL Directional Antenna
One unit set in AP mode, the other in Universal Repeater Mode (AP/CLIENT/BRIDGE) configure UM unit to access AP unit, then install in their relevant locations. Attached directional antenna and align, then you should be good to go. The WAP3205 is n/b/g rated, my setup at how gives me a theoretical 300mbs WiFi WAN. I am running 4 x WAP3205, 2 in my house, and the other 2 in remote locations that link back to my house. Rough setup as follows
ADSL router ---- WAP3205 (AP mode) ---- WAP3205 (UR mode) ----- WAP3205 (UR Mode) ---- WAP3205 (UR mode)
Simple IP setup as follows
ADSL 10.0.0.2 : 255.255.255.0
AP 10.0.0.10 : 255.255.255.0
UR1 10.0.0.11 : 255.255.255.0
UR2 10.0.0.12 : 255.255.255.0
UR3 10.0.0.13 : 255.255.255.0
AP links to ADSL via LAN
UR1 links to AP via LAN
UR2 and UR3 link to UR1 via WiFi
Rectron has the ZYXEL range in stock.
http://www.zyxel.com/products_services/home_wireless_lan.shtml
I would recomment 2 x Mikrotik SXT's and create a transparent bridge. Look at unitermdirect or scoop for the prices.
sorry if this is like spamming but i have the following that is just gathering dust:
I have the following wireless equipment available that has been used for a few days, selling at cost as have no need for it any longer, purchase all for R4800 or take what you need as listed below. Free shipping on bundle only.
2 x N(m) to N(m) - 1 Meter Cable (LMR400) @ R87 each
1 x Routerboard 433, 300MHz CPU, 64MB RAM, 3 LAN, 3 MiniPCI, L4,@R760 each
1 x 5GHz - Grid Antenna - 26 dBi, Wideband (5150-5850) @ R320 each
2 x UFL to N-Type(f) - 300mm Pigtail for Mini PCI Cards @ R45 each
2 x MikroTik MiniPCI 802.11 a/b/g, 19dBm (2.X) 17dBm (5.X), U.FL Co @ R210 each
1 x Grounded Power over Ethernet Injector 24V, 1 Amp with South African @ R140 each
1 x Acconet IP66 Enclosure, Mounting Studs @ R290 each
2 x Ubiquiti NanoStation 5.XGHz a Outdoor CPE TX 24dBm Gain 14dB @R680 each
2 x 5GHz - Heavy Duty Grid Antenna - 29.5 dBi, Wideband (5150-5850) @ R680 each
2 x NP(m) to SMA(m)RP - 1 Meter Cable (LMR195) @ R100 each
fingers crossed the wifi police dont catch you ;)
technically it's illegal to share internet via wifi beyond your property without a license, but i wouldn't worry too much. worst i guess they can do is ask you to stop. if however you're charging for it they can knock you with a heavy fine
