Wireless Issue with TP Link T4U V1 USB adapter
irBosOtter
Since I got this Archer T4U USB3 adapter I have had issues, but was mostly sorted by unplugging it plugging it back.
Media PC only has USB2 ports Win 10. First issue was the network would disconnect completely, and sometimes reconnect by itself. If not unplug and then only reconnect, reboot does not work.
Now that happened once a day, so not a big issue.
Now it seems there is a intermittent issue where the link almost "freezes" every 10 seconds exactly, ping works, but goes up to 3500ms
Now that causes streaming to fark out every 10 seconds and it's very irritating.
This only happens with this wireless adapter, tested a older one and works fine, but older only 2.4Ghz N
No interference whatsoever, all other devices does not have this issue so not the TP Link D7 router.
Anyone experienced the same?
Plenty people moan about this T4U V1 adapter on forums, so guess I should just buy another one then? Drivers up to date etc
PC 5 meters away, clear line of sight
Without copying a file
Ok, seems, not the stick as it works fine in two other laptops and another Asus stick I tested does the same thing in the media pc
Edit: Google photo backup software was the cause... uninstalled and working fine now
