Wireless Router query for Fibre
ramludh
hi ,
not sure if anyone can advise, in a fix , got a 100mb fibre installed, got ZYXEL router NBG6515 AC750 router with it, dual band , but terrible reception in upstairs rooms, on 5ghz and 2.4ghz which keeps on dropping signal, and max speed of 12 - 20mbps
looking at a mesh router system, cant put any of ubiquiti systems in the ceiling due to slabbed ceilings and the big thing for me is wifi throughput of my 100mb signal, looking at keeping it above the 90mb in each room.
any recommendations,
Many Thanks,
Ehternet cable whenever possible.
You can install Ubiquity AP on the wall
I have been testing the AirTies quite extensively for the last while and I can personally recommend it.
thanks for the feedback, i settled in the AirTies 4920, did some research and it has a 5ghz back-haul system, which helps, but the price sold me, got the special on onedayonly for 3,389 excl delivery, now just waiting till i receive them, i did read the review on here about their performance seem to be exactly what i'm looking for.
Hi, thought i will post a quick feedback for those looking into mesh routers, finally got my 3 pack Airties 4920, setup was a breeze between the 3 rooms on the app, 1 downstairs and 2 upstairs, my ceiling is slabbed, and the 2 rooms upstairs with thick walls , before getting this, my 100mb line downstairs closest to router was getting about 84mb, upstairs both rooms lucky to get 10mb, after installing the mesh all i can say is wow what an amazing difference , all 3 rooms and all corners of my house i'm able to get 95mb and above, great performance and great price, works for what i was looking for, Thanks
Thanks for the feedback!
