XBOX 360 Hard drive question
Conradl
Joburg
This is probably a noob question; but where do I buy an XBOX hard drive?? The load times are starting to get to me and I heard that the HDD will sort this out. Problem is I just can't find a HDD anywhere! I have the Arcade version....
Thanks, but that is all I seem to find is second hand ones. Where do I buy a new one? If I get a second hand one, can I upgrade the disk inside the enclosure with a standard notebook disk?
EDIT: Is R600 a good price for a 20GB?? I have no idea what it should be, but to me it seems kinda high for such a small disk!
That's about the going rate for a 2nd hand 360 20GB HDD
You should ask maestro_za if he can't source you a brand new one.
Don't compare xbox HDD prices with PC HDD prices. R600 on par for a 2nd hand 20GB. If you're comfortable with BidOrBuy, you can try this guy , for a 120GB HDD (OEM) at around R1200 incl shipping. Bit of wait as he imports it though.
zaps has a pretty good price on imported HDD's
R432 for an imported 20GB sounds pretty decent
http://www.zaps.co.za/?sm=1529
