Having Connection trouble? What DSL Modem are you using?
sscholle
I have been using a Netgear Modem for a while now, and suprisingly its been 'ok'.
I recently bought a D-Link DSL-2500U Router on my second line, and i havnt had much luck getting it to work properly. I suspect my Line is at fault. check this out...
What I dont understand is that the DSL MODE is different between the lines and the SNR Margin is also different. And these lines go the the same exchange (says the telkom techie).
Telkom says the line is fine.
Afrihost says its my modem settings (PPPoE Account).
But the modem shows these differences, who do you think is at fault?
why are you connecting at 10mbps on that one line with G.DMT ??
8mbps is max for this standard, rather change it to ADSL2+
yes they both terminate at that exchange, but they could be (and most likely are) using different routes. this would account for the different SNR values (though the different standard would also effect this)
Have you swopped the modems to see if it is still the same ???
The ADSL Mode was set to auto.
I did try another modem, same fault.
Yes, thats my tel number :)
These are my daytime pings:
Station-15-Sebastian-Scholle:~ sscholle$ traceroute speedtest.neotel.co.za
traceroute to speedtest.neotel.co.za (41.160.0.30), 64 hops max, 52 byte packets
1 192.168.1.200 (192.168.1.200) 2.066 ms 1.454 ms 1.224 ms
2 196-210-150-1.dynamic.isadsl.co.za (196.210.150.1) 203.844 ms 195.824 ms 193.572 ms
3 cdsl1-rba-vl2460.ip.isnet.net (196.38.72.217) 204.461 ms 223.753 ms 202.751 ms
4 cdsl1-rba-vl150.ip.isnet.net (196.38.73.17) 200.491 ms 223.767 ms 192.750 ms
5 core1a-pkl-te-1-2.ip.isnet.net (168.209.1.139) 211.384 ms 257.286 ms 215.631 ms
6 168.209.1.170 (168.209.1.170) 261.501 ms
196.26.0.10 (196.26.0.10) 220.499 ms
168.209.1.170 (168.209.1.170) 197.233 ms
7 neotel.jinx.net.za (196.223.14.24) 184.982 ms 197.978 ms 206.763 ms
8 41.160.0.243 (41.160.0.243) 210.706 ms 210.558 ms 245.168 ms
9 speedtest.neotelza.net (41.160.0.30) 244.817 ms 215.208 ms 185.934 ms
SOLUTION !!!
NOTE that at HOP #2, the latency goes up, this means the Exchange (ie: the DSLAM is congested). If indeed you have symptoms like that. Log a fault with TELKOM and ask them change the line's DSLAM. This can be changed quite quickly, within an hour during office hours.
SOLUTION !!!
I had Telkom absolutely insisting this was an ISP problem the other day.
HERE IS MY RESULT: now im happy
DSLAM WAS CHANGED
1 192.168.1.1 (192.168.1.1) 1.117 ms 0.758 ms 0.753 ms
2 196-210-150-129.dynamic.isadsl.co.za (196.210.150.129) 9.837 ms 10.641 ms 9.796 ms
3 196.38.73.113 (196.38.73.113) 38.670 ms 40.267 ms 37.411 ms
4 cdsl2-rba-vl150.ip.isnet.net (196.38.73.9) 40.104 ms 39.016 ms 39.655 ms
5 196.26.0.61 (196.26.0.61) 41.543 ms 41.249 ms 39.147 ms
6 196.26.0.10 (196.26.0.10) 34.557 ms
168.209.1.170 (168.209.1.170) 34.495 ms
196.26.0.10 (196.26.0.10) 34.414 ms
7 neotel.jinx.net.za (196.223.14.24) 34.376 ms 34.664 ms 35.949 ms
8 41.160.0.243 (41.160.0.243) 38.419 ms 38.918 ms 37.873 ms
9 speedtest.neotelza.net (41.160.0.30) 35.664 ms 35.037 ms 34.553 ms
