Telkom ADSL exchange and network problems: Your help needed
rpm
Admin
Staff member
Johannesburg
Hi there
There have been many complaints about ADSL problems in some areas, and to help everyone concerned we want to start threads related to specific areas to help to identify problems.
To make sure we give as much info as possible, and that the areas are easy to find, please follow the following structure when you open a thread or make a post.
  • Before you start a new thread, first search this forum to see if your suburb is not already listed.
  • If your suburb is listed, post in that thread (do not start a new thread) with the info listed below
  • If your suburb is not listed, start a new thread using the title structure listed below
TITLE
[suburb name] ADSL problems
BODY
--Give a short explanation of the problem
--Give the first six digits of our phone number (like 011 425 xxxx)
--ADSL line speed (like 1Mbps, 4Mbps etc)
--ISP name and account type (like MWEB uncapped)
--The time of day when you typically see these problems
Optional, but it will be great if you can also give the following information:
--A traceroute to Telkom.co.za
--The actual sync speed of the line
--The attenuation stats of the line
Sample entry here: http://mybroadband.co.za/vb/showthread.php/546791-ADSL-problems-in-Midstream-Estates
How to do a traceroute
How to do a traceroute (Thanks MickeyD)
Open a DOS window (Run -> cmd, enter), type the following command:
C:\tracert telkom.co.za {enter}
Tracing route to telkom.co.za [196.43.22.222] over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 11 ms 15 ms 9 ms ti-224-140-01.telkomadsl.co.za [105.224.140.1]
3 27 ms 27 ms 29 ms ti-226-0-06.telkomadsl.co.za [105.226.0.6]
4 28 ms 28 ms 27 ms ti-226-0-13.telkomadsl.co.za [105.226.0.13]
5 35 ms 35 ms 34 ms 165.165.214.213
6 54 ms 51 ms 51 ms 196.43.39.162
7 59 ms 59 ms 59 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
8 53 ms 52 ms 52 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.34]
9 54 ms 54 ms 54 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Trace complete.
Select all, copy, paste to MyBB and then edit out any personal details!
PS. stop any other Net activity to give a fair result....
Swellendam, Western Cape: Occasional data outages during the day
Phone number: 028 514 xxxx
ADSL line speed: 2Mbps ADSL
ISP name: Telkom Internet
Time: "Normal" working hours .. e.g. 08h00 through 17h00 ... Occasional ADSL outages - a re-boot of my router sometimes fixes this.
Sync speed of the line: 2048 kbps
Hi there
Can you please start a new thread with this info:
Thread title: Swellendam ADSL problems
Body
@RPM when you say search this forum do you mean the 'Telkom ADSL area problems' forum or the entire myBB forum. The reason I ask is that I have been giving some info about the upgrade status (ETA's) of the Durbanville area and I would like to share it with the forum users, so I am assuming if I create the thread in this forum that would be the right place ? There are already a few 'Durbanville ADSL problms' threads, but not specifically in the 'Telkom ADSL area problems' forum.
@Psykro, you can post it in the Telkom ADSL area problems. I believe (until corrected) that would be the correct place. :)
This is a brilliant idea and i missed seeing this section. TelkomZA is certainly making an impact :p
1 1 ms 1 ms 1 ms
2 * * * Request timed out.
3 83 ms 89 ms 189 ms
4 257 ms 198 ms 59 ms
5 115 ms 99 ms 59 ms
6 116 ms 99 ms 88 ms 8ta-150-177-01.telkomadsl.co.za
7 * * * Request timed out.
8 158 ms 108 ms 68 ms
9 96 ms 89 ms 74 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za
10 89 ms 99 ms 69 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.34]
11 84 ms 79 ms 82 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za
Trace complete.
Fish Hoek. Almost unusual in the evenings
I have a flapping line in the evening. It's almost impossible to get to any websites, including Telkom. I have the highest speed available (whatever that is) from Telkom.
Here's what I get around 21:10
traceroute to telkom.co.za (196.43.22.222), 64 hops max, 52 byte packets
1 10.0.0.2 (10.0.0.2) 5.730 ms 1.456 ms 1.732 ms
2 ti-225-8-01.telkomadsl.co.za (105.225.8.1) 9.050 ms 8.076 ms 8.097 ms
3 ti-226-0-06.telkomadsl.co.za (105.226.0.6) 461.616 ms 31.228 ms 9.704 ms
4 ti-226-0-13.telkomadsl.co.za (105.226.0.13) 10.021 ms 9.370 ms 8.632 ms
5 165.165.214.213 (165.165.214.213) 9.970 ms 10.256 ms 13.690 ms
6 196.43.39.162 (196.43.39.162) 32.468 ms 32.038 ms 31.477 ms
7 rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za (196.43.23.6) 33.462 ms 35.108 ms 34.546 ms
8 nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za (196.43.23.34) 34.168 ms 34.894 ms 33.870 ms
9 nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za (196.43.22.222) 34.669 ms 34.348 ms 34.444 ms
Hi there
TITLE
BODY
Fish Hoek. Almost unusable in the evenings
Hi there
TITLE
BODY
011 318 ****, 1mpbs MWEB.
1 <1 ms <1 ms <1 ms 192.168.12.1
2 11 ms 11 ms 10 ms 41-132-12-1.dsl.mweb.co.za [41.132.12.1]
3 13 ms 13 ms 13 ms 197-80-96-210.jhb.mweb.co.za [197.80.96.210]
4 13 ms 13 ms 14 ms vl-92.vic-hscore-2.mweb.co.za [197.80.2.2]
5 19 ms 19 ms 19 ms tengig0-7-0-2.12.vic-p-1.mweb.co.za [197.80.5.24
1]
6 14 ms 14 ms 14 ms tengig0-0-0.vic-pr-1.mweb.co.za [197.80.4.141]
7 14 ms 14 ms 14 ms jhb.telkom-ipnet.co.za [197.80.4.117]
8 14 ms 14 ms 14 ms 196.43.25.137
9 14 ms 14 ms 14 ms 196.43.39.166
10 16 ms 16 ms 16 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.4
3.23.6]
11 20 ms 17 ms 17 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.34]
12 20 ms 18 ms 18 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43
.22.222]
Trace complete.
Hilton - PMB : KZN --- ADSL problems
BODY
--Line flapps between 9-10 pm
--033 343
--1Mbps
--Telkom line, telkom capped account (also have a reserve capped Afrihost account which does the same thing)
-- 9 to 10pm
--A traceroute to Telkom.co.za --> na
--1Mbps
--The attenuation stats of the line --> na
Bergbron Johannesburg
[Bergbron] ADSL problems
Extremely slow response on websites and streaming
011 477 xxxx
--ADSL line speed 4Mbps
-- MWEB uncapped
--All day long, as i work from home
Rosebank Telkom Server - terribly slow speed..
Not sure if any body else experiencing the terrible slow internet in the area... Telkom told me its a problem with a server n still after a one year situation is worse...
I get speed of 0.04 on 1 mbps line so yeah my money is going on waste each month tried different service providers so far but result is same...
Phone number 011 264 xxxx
ADSL line speed 1Mbps
Afrihost uncapped, Mweb uncapped
whole day terrible service
cant even open telkom site most of the days... forget about anything....
My problem is: ADSL Broadacres - so underutilised that there are no plans to upgrade to 10Mbps or VDSL - now what? Service runs perfect though on 4Mbps.
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\Ric>tracert telkom.co.za
1 <1 ms <1 ms <1 ms 192.168.0.1
2 571 ms 608 ms 602 ms ti-224-116-01.telkomadsl.co.za [105.224.116.1]
3 686 ms 579 ms 660 ms ti-224-0-06.telkomadsl.co.za [105.224.0.6]
4 12 ms 11 ms 11 ms ti-224-0-13.telkomadsl.co.za [105.224.0.13]
5 12 ms 12 ms 11 ms 165.165.216.221
6 12 ms 12 ms 12 ms 196.43.39.166
7 776 ms 431 ms 379 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.4
3.23.6]
8 853 ms 802 ms 855 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.34]
9 559 ms 527 ms 454 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43
.22.222]
Trace complete.
Bryanston Johannesburg
The line freezes when online. Sometimes it needs a router reboot to fix it
Tel No: 011 706xxxx
Time: anytime during working hours
ADSL line speed: 4MB uncapped
ISP: MWeb/Telkom line, (MWeb 4MB uncapped)
Sync speed: 3.4MB down, 0.34MB up
Attenuation: Well over 55%
Telkom suggests that we lower the speed to 2MB to IMPROVE the stability
Gave up on Telkom a long time ago. Had months of congested, unusable ADSL in Durbanville, Cape Town. One *** story after another, so left them. Blissfully been using a WISP ever since.
You just can't trust Telkom.
Apparently, there was a network failure in a nearby area (11 Feb 2013). Traffic was rerouted to the Salt River exchange and it became horribly congested. Tracert to telkomsa.co.za was over 200ms for hops 2-12 during the day. Went through the painful process of reporting it to mweb multiple times, providing evidence, getting it escalated, getting them to open up a case with hellkom.
Exchange was upgraded two months later. The fact that it is in the heart of a business area probably had a lot to do with the speedy upgrade. It's sorted now. Although, not as brilliant as before - I was getting 10-15ms to the mweb server (<50km) and now I am getting 30-35ms. Good luck guys
Sonheuwel ADSL Problems
- Since November 2012 my line has been unstable. Download speeds are hardly ever stable, internet browsing is extremely slow, my average ping is also higher than before.
When playing games that sync to master servers overseas the game lags or freezes horribly making it unable to play games such as Diablo 3, Guild Wars 2 etc...
-013 -745 xxxx
-Currently on a 2Mb (Degraded from a 4Mb since we were being ripped off with the crap service/congestion and wasn't worth paying for the 4Mb)
-Telkom 2Mb Uncapped
-Typically throughout the entire day except after 12pm until probably 6am (So when everyone sleeps :/ )
-Tracing route to telkom.co.za [196.43.22.222]
1 <1 ms <1 ms <1 ms 10.0.0.2
2 26 ms 26 ms 26 ms ti-224-56-01.telkomadsl.co.za [105.224.56.1]
3 29 ms 48 ms 28 ms ti-224-0-06.telkomadsl.co.za [105.224.0.6]
4 37 ms 44 ms 29 ms ti-224-0-13.telkomadsl.co.za [105.224.0.13]
5 31 ms 29 ms 30 ms rrba-ip-hsll-1-wan.telkom-ipnet.co.za [196.25.39
.37]
6 39 ms * 29 ms 196.43.39.162
7 30 ms 29 ms 30 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.4
3.23.6]
8 33 ms 32 ms 35 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.34]
9 33 ms * 34 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43
.22.222]
Trace complete.
ADSL Link Downstream Upstream
Connection Speed 2048 kbps 512 kbps
Line Attenuation 33.5 db 18.5 db
Noise Margin 23.5 db 13 db
And an extra speedtest
http://www.speedtest.net/result/2900027728.png
