10 Mbps ADSL availability checker
If you have been upgraded to 10Mb, indicate which Province you live in.
  • The Eastern Cape
    Votes: 3 0.9%
  • The Free State
    Votes: 2 0.6%
  • Gauteng
    Votes: 33 9.8%
  • KwaZulu-Natal
    Votes: 17 5.1%
  • Limpopo
    Votes: 1 0.3%
  • Mpumalanga
    Votes: 0 0.0%
  • The Northern Cape
    Votes: 0 0.0%
  • North West
    Votes: 2 0.6%
  • The Western Cape
    Votes: 45 13.4%
  • No upgrade as yet
    Votes: 233 69.3%
  • Total voters
    336
Tested:
Centurion - No 10 Mbps
Northcliff - Supports 10 Mbps
Fourways - No 10 Mbps
Midstream Estates - No 10 Mbps
Moreleta Park - No 10 Mbps
Garsfontein - No 10 Mbps
Oakdene - No 10Mbps
This service can not be converted to 10Mbps Fastest DSL at this stage. Please check again in future as we are continually upgrading the network.
Table View, CT. supports 10 Mbps. But telkom wont upgrade if asked. "It will be done when its done" So its a luck of the draw, even if the exchange does support it.
Fourways (011 465) - 10Mbps active. I get around 6.8Mbps down/0.66Mbps up over IS.
Your exchange supports up to 10Mbps fastest ADSL. The provision of such a service is subject to port availability, distance, copper quality and line sync speed limitations.
I have been told by numerous Hellkom staff that my line is 1 of those that will be upgraded. Yet this checker says "This service can not be converted to 10Mbps Fastest DSL at this stage. Please check again in future as we are continually upgrading the network."
My work ADSL line which is on the exact same exchange as my home line (031-267 ****) has already been upgraded. I don't think even Hellkom know what they are doing.:mad::mad::mad::mad:
Amandasig (Pretoria-North)
Constantia, Cape Town - 021 794: No [according to Telkom's checker], but according to WebAfrica=yes.
i still think it is all a bunch of crap, if they could not 'upgrade' all the 4mb users to 10mb they should have offered the 10mb as a new service and you can then upgrade if you want to. Now some people get the 'upgrade' while others get the run around when asking what is going to happen in your area. in the mean time pay the same as the guys getting the 10mb service, sux.
why not drop the 384 and start at 512, then 4mb and then 10mb.
i remember when i applied for my DSL Telkom said that they need to test my line to see what speed it can handle. with this 'upgrade' you don't get the choice and as far as i am aware G.DMT modulation can handle 12mb, which is what most of us use, so what is their prroblem.
At one point during the whole 'upgrade' process i had a download speed of 1mb/s, this lasted for about 30min. at that point i thought that i was part of the upgrade, when i got home in the evening it was back to normal. Called Telkom the next day and no one could tell me why that happened, one reason they gave was that the field tech guys were working on a problem in the area and that they may have had the lines opened for testing. so if i could do it then why not now, that so far no one can answer.
Yes it is a bit of sour grapes cause i experienced the added speed and had it taken away.
Boston, Bellville - No 10Mbps
My D-link router does however give the following stats.
Downstream Upstream
SNR Margin (dB): 29.8 19.0
Attenuation (dB): 32.0 18.5
Output Power (dBm): -1.4 4.4
Attainable Rate (Kbps): 9248 896
Rate (Kbps): 384 128
K (number of bytes in DMT frame): 13 5
R (number of check bytes in RS code word): 0 0
S (RS code word size in DMT frame): 1 1
D (interleaver depth): 1 1
Delay (msec): 0 0
Guess Telkom must still get to the exchange and activate the service.
"This service can not be converted to 10Mbps Fastest DSL at this stage. Please check again in future as we are continually upgrading the network" thats what i get when i put my mates 031563xxxx number in and he has 10mb what a FAIL!!!! useless tool:mad:
Woodstock, Cpt:
"Your exchange supports up to 10Mbps fastest ADSL. The provision of such a service is subject to port availability, distance, copper quality and line sync speed limitations."
Seems I'm only getting 6144kpbs though, bummer.
