johandutoit2000
OK. Figured the PPP log part out.
ic said:MrG, I assume you're quoting that from MSDN or somewhere? - anyways that "glitch on the ISP's end" probably assumes you're working off a fixed line connection - as opposed to a wireless connection with signal fluctuations, going back to:What that tells me [in this wireless context] is that signal quality is probably not all that good in johandutoit2000's conditions [causing packet loss] - maybe try moving the Samsung around to get a better quality signal...
johandutoit2000 said:OK. Figured the PPP log part out.
vodacom3g said:...1) Can you connect to the network with the phone directly, i.e. not via the PC and can you then browse.
If so, the problem lies on the PC side of things. ....
grim said:Then it's someting on the pc maybe try to create a new connection.
johandutoit2000 said:Grim,
Please read the rest of the thread before commenting.
Vodacom3g,
Moved the sim card to my wife's D600 last night. Everything worked first time. Then tested again with ZV10. No Luck. The only thing left is a firmware upgrade. If that does not work, I would have to return the phone. Would you agree?
johandutoit2000 said:Will he teach me how to upgrade the firmware myself; otherwise I dont see the point?
