Adsl Errors with CRC and SRN
marclubout
Hi
I have upgraded to a 4mb line but only get 2mb and i have used wage , afrihost , mweb no isp makes a difference
My snr might be low and there ARE ALOT OF CRC ERRORS....i dont know if any 1 has any insight please assist
DSP Firmware Version E.25.41.55 A
Connected :true
Operational Mode: G.Dmt
Annex Type: AnnexA
Upstream: 512000
Downstream: 4096000
SNR Margin(Upstream): 13 dB
SNR Margin(Downstream): 11.5 dB
Line Attenuation(Upstream): 23.0 dB
Line Attenuation(Downstream): 42.0 dB
CRC Errors(Upstream): 3720
CRC Errors(Downstream) 0
Latency(Upstream) Fast
Latency(Downstream) Fast
Thanx alot :-D
My SNR can drop as low as 11dB at certain times of the evening and I still have a pretty stable connection.
What modem do you have, certain modems handle bad lines better than others? I have found Netgear to be pretty unstable on bad lines compared to D-Link and Linksys.
i have a billion 400(ithink i know its a billion) the basic router u get from telkom . ****ty router but eish its bad i get no speed whatsoever
Try a new router had same problem on my billion 400g and once I upgraded to the TP-Link one I never had problems again
