Sir Peel-a-Lot
- Nov 20, 2020
HI. Looking for an Android streaming box for my (technophobe) dad, was gonna buy him the same one I've got, but the remote has no media controls (pause, stop, play) which will just be a PIA for him to constantly move the cursor around the screen to do anything. It must work with iPlayer. If it's not simple to use he just won't use it.
I believe the Amazon Fire Stick is the only device we can get in SA that natively supports the iPlayer app, as in, you don't have to side load the APK. And the Fire Stick comes in a few different options so you can have the media controls on the remote.
Anyone using this setup and can confirm they can install from Play Store & control the iPlayer app with Fire Stick remote?
Any other suggestions welcome. Thanks.
