Android tasker help please
Dee96
Hi guys
i just got tasker and it doesnt work!. Basically the profiles activate but the task doesnt execute, even when i go to the task and press the play/test button. Nothing happens.
I created 2 tasks to test, vibrate and increase brightness and both done work. Even gps on doesnt work.
I have a Huawei s7 slim running froyo and version 1.2.1 of tasker. I have screen shots but cant upload from mobile.
That's odd. I used Tasker for a long time across quite a few devices with no issues.
Have you given Llama a look? Bit easier to use.
What about updating the tab to the most latest version of Android you can & try again.
Froyo is the latest version it support.... As for lamma.... I would try this but i paid over 50 bux for tasker
Strange, I'm running it also on my HTC sensation, and it working fine for me.
The task I can't get right, is to auto run a WOL profile every weekday morning at a certain time, so by the time I am out the shower, my system is already on. Just can't seem to get the task right.
Tried getting the GPS to turn on whenever I open up the Adidas miCoach app, but it says GPS now has to be manually started.
