AP Antenna orientation on wall.
Rickster
EVGA Fanatic
Joe'berg
So I was just wondering is this the right way to orientate the antennas for wall mounting?
Cheers.
I played around in past and found antenna orientation did not make any difference to signal strength.. This conclusion may be incorrect as I used the most "expensive" tool available to Joe public - two different apps - to measure signal strength
