jaco.slabbert
- Jan 11, 2013
Post all your Arduino, ESP16, ESP32, ESP8266 etc projects here. This thread is for inventers, programmers, hackers, engineers. Let us get creative.
My first ESP32 Project. High quality, long lasting wifi soil moister sensor with an internal webserver.
https://www.instructables.com/id/ESP32-WiFi-SOIL-MOISTURE-SENSOR/
www.instagram.com
This look like a great Arduino / ESP32 / ESP8266 course.
https://www.edx.org/course/a-subjective-introduction-to-the-iot
www.robotics.org.za
ACM/BSK is just the supplier name (I think). Just remember that the Pro Mini must be programmed with a FTDI serial chip or similar. I would go for the Pro Micro, which is faster, same form factor-ish, and has a USB port to connect to your computer. The Pro micro is more expensive, but have much more features (USB HID, USB Serial). Just go with the 5V one.Question, i want to try out some arduino things, however i see some acronyms i don't understand, i'll be buying a Arduino pro mini 16mhz, though on sites like communica i see acm and bsk versions, can somebody tell me what that means? i see various other items that also have the same acronym.
aah cool, i was wondering what happens with the birdsscore?I have not checked the score. It plays the game for a couple of minutes until the first "bird" appears.
The bird flies higher than the sensor ... You could add a second LDR to fix that issue but then when the game starts speeding up the timing will start to fail and the dino will start hitting stuff.
I'm sure there are ways to fix it but I will leave it as is for now.![]()
