wizzard2
Hi Everyone
So I've bought a new car , Audi A4 2011 2.0T Multitronic (44k kms on clock)
Since buying the car I discovered that it uses an insane amount of oil
I don't even have the car two months and probably drove it just under 2000km or there about.
After the first 2-3 weeks the oil light came on and the oil level marker was empty, I threw in a few pints and it showed full again. I filled up last week and it was nearly empty again, I threw in more oil (3 pints) . This can't be normal right? Then I looked in the book and saw it uses about 1ltr every 1000km. I thought to myself WTF. Still not convinced that this is normal so I did some googling and found it to be a common problem that even resulted in a class action suit agains Audi
You can find it here http://www.carcomplaints.com/news/2014/audi-oil-consumption-lawsuit.shtml
Contacted the person I bought the car from and he basically just said contact Audi.Which I did and they said to bring it in and they going to do a oil consumption test. Zero about cost. "Starting to get worried" especially about potential costs.
Has anyone else had this issue? What are your thoughts and what do I do next. Has anyone had the issue and got it fixed if so at what cost?
The Funky Tech Guy
The Funky Tech Guy
