Battery specs and prices
Maintenance & Cautions
※ Charged with recommend voltage, ensure battery can be full recharged.
In general, recharge capacity should be 1.1-1.15 times discharge capacity.
What does the bold section mean.
It points to the general inefficiencies of lead type batteries and that your system must be designed to have the capacity to put 1.15 times what you used, back into the battery.
Means if you discharge 100ah you need to pump 115ah in battery to recharge it
15% energy is lost in discharge recharge cycle
Ok I see. But the charger can't do that right.
Charger gives what battery asks
If battery needs an 15% extra charge battery will take charge till this is met
Same as if battery needs 20% extra
If battery fubar and keeps asking charge , charger will keep trying to charge battery even if it is 400% overcharged
^ This. That's why it is extremely important to invest in a really good charger. I also take my batteries back to Battery Center every 6 months for a free maintenance cycle and for what they call a "mechanical" recharge/refurbish.
The ultimate key to battery maintenance is a very shallow discharge. So rather run two or even three batteries in parallel.
Also remember when you run batteries in parallel, it takes longer for proper voltage regulation to take place.
The more frequent your discharge cycles between re-charge, the shorter your battery life becomes.
Lead-acid batteries were never designed for these high frequency discharges like we put them through during our lives of constant load shedding.
There is a company in durban also but really expensive the battery bank is 111000 for 400ah 48v system lifepo4
What about the OmniPower GEL batteries sold by Sinetech. The specs look decent:
http://www.sinetech.co.za/opssolarbatteries.htm
http://www.sinetech.co.za/ops_batteries/OmniPower-Battery.pdf
Okay added them, though be warned I just pulled the first prices I could find on the internet, if anyone has prices from sinetech or better prices for the batteries (as with all the other batteries) let me know and I will update the pricing :p
Added.
I just got prices from Sinetech:
EXCL VAT
OPS-120-12 - R 1 952
OPS-180-12 - R 2 919
OPS-260-12 - R 3 940
I believe track record is very important where longevity is concerned.
Specs may say one thing, but the proof is in the performance.
Do you have a source for that kind of info?
Because I want my batteries in the house, my search was more directed towards totally sealed batteries, so first choice would be LiFePO4 based and then AGM / Gel. Then there are also details like cycle life, affordability, availability, size, weight, etc. :)
I see Batterysolutions / Current Automation have a Ceil / Excide Solatron 6SGL range that claim pretty good specs:
http://www.batterysolutions.co.za/solar-batteries/ceil-6sgl-200
http://www.batterysolutions.co.za/files/bat/1412755238_CEIL%20Solatron.pdf
I did say as much in my first post, however specs are part of the picture as well, having specs is a good starting point :)
Currently most people are flying completely blind, they have neither specs nor any information on track record.
Site says 6v, specs say 12v - which is it? Also did you get a price? :P (I've added the specs to list in the meantime)
Totally agree. We should probably have a thread to compile people's experiences together with some usage data.
I'm just shocked how few batteries even have basic cycle information available :p (And not just the cheap ones on bidorbuy either)
rectifier.co.za Sent me the same spec sheet without cycle information four times in a row and then started ignoring me when I pushed them for cycle info on the royal batteries. (Which they sell as 'deep cycle')
Scary stuff...
