C905 help please
Nic21
Hi All
I'm new here and hoping I can get helped.
I just acquired a C905 and am having major :mad: by not being able to get the Wayfinder GPS service working.
It keeps on saying that it cannot connect to the internet services and I must check that an access point has been selected.
Please please help
Thanks.
Ok this is easy to solve: Go to settings>connectivity>internet settings. In the "connect using" area, make sure an internet profile is selected (select the one that sound like like "3G" or "internet" or "hsdpa"). I there are none that you can select, you should phone your service provider (like Vodacom or Cellc) and ask them if they can send you your "internet settings". Or if you are using vodacom just dial *111# and go to the device setup sub menu.
Hope I could help! :D
