cheapest decent rechargeable wireless mouse?
ronz91
Hey guys
Looking for a cheap rechargeable wireless mouse.
Go for Logitech.
Nothing else.
Battery will last you 6 months.
I used the mouse from Logitech which came in a combo with my K270 keyboard, don't think I have replaced the batteries and had them for a long time and also get the one with the option to turn off so it doesn't continue to use the battery when you not using it.
It is the MK270 combo, but they probably sell them seperately.
Hey guys
If the Logitech M705 is within your price range it is a fantastic mouse for every day use. Also you only need a new set of AA batteries once every couple of years. I bought mine three years ago and use it at work 5 days a week and I haven't needed a new battery yet. Right now it says 51 days battery life left!
I have a theory that the batteries are only there for weight and that the mouse actually runs off the tears the innocent or something... Seriously it is a great everyday mouse!
[Edit] Check out Esquire I havent been able to find them cheaper anywhere. The price they have it for is the same price I paid on a special somewhere three years ago. Takealot sells them for close to double the price.
Logitech all the way :D I don't think any other mouse comes close in terms of battery life. I'm using the mouse that came with my mk320 desktop & maybe every 6 months i have to replace the battery
