Hi Guys,
Some help or advice please?
I have DSTV infrastructure at home, and would like to hook up my OVHD to this infrastructure. My DSTV is disconnected, so not using the DSTV decoder.
I have read from other posts that this is indeed possible, but I am battling somewhat to "plug and play" this setup.
I haven't fiddled with the LNB. All that I did was remove the LNB cable from the Explora decoder, and plug it into the OVHD decoder, but when I switch the decoder on, it says "no satellite found".
As I said, all I did was plug in the LNB cable (from the DSTV switch that came with the Explora) into the OVHD decoder. Do I need to replace the DSTV switch? Does the DSTV switch only work with DSTV decodes or will OVHD work on this switch? If OVHD will work with the switch, do I need to change the port that leads from the switch to the decoder?
I have a Dual LNB that feeds into the DSTV switch.
Thanks for all the help guys
