vicness
Hey guys,
Im having a problem with connecting to msn messenger. Im using a laptop, and when my cable is plugged in to the router it connects perfectly to messenger when i use it in bridge mode. If i try to connect wirelessly to msn it gives me error code 81000306 , and also if i try to connect normally to messenger via cable in routed mode, it gives me the same error....
What could the problem be? Any help would be appreciated..
