Hi guys
So this is what I've been having a problem with.
I switched ISP's from Vox to Cybersmart at the beginning of the month; and since then I have been having persistent issues with my internet. Although the SpeedTest results always show up as being fine; the actual usability of the line is not good at all.
Since the swap I have experienced the following issues
- Unless I am streaming from youtube; I cannot access high quality streams anymore and even the lower
resolutions will buffer constantly and sometimes will require restarts or they simply stop working.
- Browsing is problematic as should I try open multiple tabs; load times are very with a high chance of pages
simply timing out.
- Downloading is almost pointless; with the maximum recorded speed being 109KBps (at about 3AM); with the
average speeds being at about 25 KBps. (This issue persists regardless of when/where/what I download)
- Gaming is very difficult. Even when I have low pings there are almost consistent spikes occurring.
- At least once every 3 hours the line will just drop and require a router reset in order to operate properly again.
I am on Cybersmart 4Mbps Home Uncapped Account with Vox still handling the line. I have contacted support on both ends and no resolution has been found yet. I submitted a new ticket on Friday but have as of yet to receive a response from Cybersmart.
They have reset the ports; checked for noise on the line and can't seem to identify the problem.
Thank you in advance for your assistance and advise
simply timing out.
