joppenheim
- Jun 11, 2009
Hi there
Does anybody know if its possible to buy a multi-core coaxial (RG6) cable?
The reason I ask is that to install DSTV Explora with Xtraview will require up to 7 coaxial cables:
(7 coaxial cables make your home look like you are running a Google server!)
2x from LNB to DSTV Explora decoder
2x from LNB to DSTV Xtraview decoder
1x from DSTV Explora to Xtraview for the "heartbeat" link.
If a multi-core (3 cores to start), means you would be able to connect all the devices together with a single cable (and a splitter).
Any suggestions?
Joe
Any suggestions?
Joe
