External Antenna for Huawei E272 modem?
nuyork
JHB
Does anyone have any data on where one can get an external antenna connector or attachment for the Huawei E272 modem?
Are Poynting selling these? Can they be used with their external 3G antennas?
Thanks!
Thanks!
The E272 has a cradle with a standard SMA connector on it. so the Poynting antennas will plug straight in.
However, I don't know if the cradles are available yet. Maybe ask your friendly, local Vodashop.
I'll also see what I can find out.
Yup, there is a cradle available. But Poynting are not selling them. You can only purchase the cradles directly through VSP.
Wonder why?
Would rather get a whole 3G yagi kit from Poynting, one time.
where would you plug an external antenna into the E272? mine is as small/flat as a Mcdonalds cheesburger patty.
There is a small port in the bottom of the unit. There's a picture somewhere here on the forums.
Wonder why?
It's simple IMO - Vodafone would be purchasing large volumes of these from Huawei [the manufacturer of the cradles and associated E272 modems], which means that Vodafone would be able to supply these somewhat cheaper than Poynting would be able to, obviously Vodafone would then supply Vodacom|VSP with some of these cradles - much the same way that the E272 modems etc end up in SA.
Yeah, I understand...
So who developed the pigtails and connects for the 3G red datacards? Standard issue antenna connections?
They were very difficult to get initially but Poynting and others eventually managed to source the connectors for the cards and could make up the pig-tails.
The E272 cradle uses a standard SMA connector, so no pig-tails are needed, the Poynting antennas will plug straight in.
Cradle for HUAWEI E272 now in stock
A quick note to let everyone know that PoyntingDirect now has stock of the Cradles for the HUAWEI E272 modem.
