Face time camera - best recording quality settings
Grant
just around the corner
so . . . a friend needs to put together a quick presentation of sorts.
she is going to use one of my laptops to create the video aspect of it.
what setting would provide the highest quality video recording ?
the file size does not matter.
ie:
compression type
frames per second
key frame rate
**frame rate in particular, means nothing to me - no idea what that is about
ie:
compression type
frames per second
key frame rate
A cellphone would probably do a better job.
